The purpose is to show how the SDRAM can retain data written after entering STOP mode. STOP mode is a CPU low power mode which stops all peripherals clocks in the 1.2V domain. Only internal SRAM and registers content are preserved in this mode. After SDRAM initialization, the data is written to the memory and a "self refresh" command is sent to the SDRAM. The program waits for USER button to be pushed to enter the CPU in STOP mode, the LED3/LED4 are then turned ON. The wakeup from STOP mode is done when pushing USER Button again (LED3/LED4 switch off) and the CPU returns to RUN mode. At this time, the system clock is reconfigured using the function SystemClock_Config(). Finally, a "normal mode" command is send to SDRAM memory to exit self refresh mode. The data written to SDRAM is read back and checked. |
STM32F407VET6,使用cubeIDE下载跑不起来
FLASH擦除轮询等待时CPU真的会轮询吗
STM32F417 RTC读取亚秒寄存器
STM32N6通过X-CUBE-AI部署模型到工程后,如何调用API函数接口?
stm32H743使用CubeMxAi导入模型文件,需要将测试数据进行识别,不知道如何传入参数
STM32F405ZGT6 批次22+ 问下这颗料,60度烘烤12小时后,出现鼓包,是怎么回事? 原厂有标准的烘烤温度范围 跟时长范围吗?
非官方开发板第一次下载成功,之后就各种失败
STM32H5F/E 相比 STM32F4 系列最大的优势是什么?
ST TOF问题请教
