STM32_USB-FS-Device_Lib_V4.1.0 file :usb_core.c funciton name: RESULT Standard_ClearFeature(void) code : if (wIndex0 & 0x80) { /* IN endpoint */ if (_GetTxStallStatus(Related_Endpoint )) { ClearDTOG_TX(Related_Endpoint); SetEPTxStatus(Related_Endpoint, EP_TX_VALID); } } else { /* OUT endpoint */ if (_GetRxStallStatus(Related_Endpoint)) { if (Related_Endpoint == ENDP0) { /* After clear the STALL, enable the default endpoint receiver */ SetEPRxCount(Related_Endpoint, Device_Property.MaxPacketSize); _SetEPRxStatus(Related_Endpoint, EP_RX_VALID); } else { ClearDTOG_RX(Related_Endpoint); _SetEPRxStatus(Related_Endpoint, EP_RX_VALID); } } } question: i saw that status of IN endpint was set to VALID(EP_TX_VALID) after recover from HALT; i wonder why we don't set the status to NAK; The USB spec doesn't specify how to leave the endpoints after a halt is cleared. but for an interrupt IN endpoint such as a HID device,at that point when the endpoint recover from halt status,the device will send an packet with uncertain data to the host,since the host automatically query the device by IN token in a determined interval constantly,and it can be quite possible for the packet buffer contains uncertain data at that point; possible advice: just set the status to NAK,firmware could set it to VALID if necessary data get ready to transfer to host later. 主要意思是在一个端点从HALT状态恢复后,发送是有效的,那样的话,比如对于一个中断型的IN端点,会自动发给主机一个数据包,这个数据包的内容是不定的,很可能包含未知的数据; 疑问就是为何不在端点恢复后将发送端点设置为NAK,在固件准备好数据后在由固件设为VALID。 |
STM32F401RBT6 USB 大容量存储设备问题
USB OTG 主机枚举问题
STM32F042 在启动文件内跳转至 USB DFU Bootloader
B-L475E-IOT01A 无法枚举为 USB DFU 设备
USBX Audio Class frame done 不触发回调
STM3210C-EVAL USB 官方例程调试报错
STM32F103 全速 USB 大容量存储方案咨询
STM32H573ZI 全速 USB
STM32F2xx 是否有 UVC 相关示例工程
USBX在F407上创建CDC不能正常使用
