小弟去下載USB的3.3.0的資料庫,裡面有EVAL的Virtual COM Port程式,想要一直到我的板子上,對照了電路圖,小弟的板子不是市面上的開發板,用的IC是STM32F102R8,USB的PULL UP控制是在PB9,照原本的是設定在platform_config.h裡設定是PD9,把它修改成PB9後變成一直在卡在USB中斷那邊,後來追到stm3210b_eval.h裡的PB9有重複定義把它改成PD9,platform_config.h裡設定是PB9,但是還是卡住在USB中斷,修改的部分程式如下: stm3210b_eval.h #define BUTTONn 8 /** * @brief Wakeup push-button */ #define WAKEUP_BUTTON_PIN GPIO_Pin_0 #define WAKEUP_BUTTON_GPIO_PORT GPIOA #define WAKEUP_BUTTON_GPIO_CLK RCC_APB2Periph_GPIOA #define WAKEUP_BUTTON_EXTI_LINE EXTI_Line0 #define WAKEUP_BUTTON_EXTI_PORT_SOURCE GPIO_PortSourceGPIOA #define WAKEUP_BUTTON_EXTI_PIN_SOURCE GPIO_PinSource0 #define WAKEUP_BUTTON_EXTI_IRQn EXTI0_IRQn /** * @brief Tamper push-button */ #define TAMPER_BUTTON_PIN GPIO_Pin_13 #define TAMPER_BUTTON_GPIO_PORT GPIOC #define TAMPER_BUTTON_GPIO_CLK RCC_APB2Periph_GPIOC #define TAMPER_BUTTON_EXTI_LINE EXTI_Line13 #define TAMPER_BUTTON_EXTI_PORT_SOURCE GPIO_PortSourceGPIOC #define TAMPER_BUTTON_EXTI_PIN_SOURCE GPIO_PinSource13 #define TAMPER_BUTTON_EXTI_IRQn EXTI15_10_IRQn /** * @brief Key push-button */ #define KEY_BUTTON_PIN GPIO_Pin_9 #define KEY_BUTTON_GPIO_PORT GPIOD------>B改D #define KEY_BUTTON_GPIO_CLK RCC_APB2Periph_GPIOD------>B改D #define KEY_BUTTON_EXTI_LINE EXTI_Line9 #define KEY_BUTTON_EXTI_PORT_SOURCE GPIO_PortSourceGPIOD-->B改D #define KEY_BUTTON_EXTI_PIN_SOURCE GPIO_PinSource9 #define KEY_BUTTON_EXTI_IRQn EXTI9_5_IRQn /** * @brief Joystick Right push-button */ #define RIGHT_BUTTON_PIN GPIO_Pin_0 #define RIGHT_BUTTON_GPIO_PORT GPIOE #define RIGHT_BUTTON_GPIO_CLK RCC_APB2Periph_GPIOE #define RIGHT_BUTTON_EXTI_LINE EXTI_Line0 #define RIGHT_BUTTON_EXTI_PORT_SOURCE GPIO_PortSourceGPIOE #define RIGHT_BUTTON_EXTI_PIN_SOURCE GPIO_PinSource0 #define RIGHT_BUTTON_EXTI_IRQn EXTI0_IRQn /** * @brief Joystick Left push-button */ #define LEFT_BUTTON_PIN GPIO_Pin_1 #define LEFT_BUTTON_GPIO_PORT GPIOE #define LEFT_BUTTON_GPIO_CLK RCC_APB2Periph_GPIOE #define LEFT_BUTTON_EXTI_LINE EXTI_Line1 #define LEFT_BUTTON_EXTI_PORT_SOURCE GPIO_PortSourceGPIOE #define LEFT_BUTTON_EXTI_PIN_SOURCE GPIO_PinSource1 #define LEFT_BUTTON_EXTI_IRQn EXTI1_IRQn /** * @brief Joystick Up push-button */ #define UP_BUTTON_PIN GPIO_Pin_8 #define UP_BUTTON_GPIO_PORT GPIOD #define UP_BUTTON_GPIO_CLK RCC_APB2Periph_GPIOD #define UP_BUTTON_EXTI_LINE EXTI_Line8 #define UP_BUTTON_EXTI_PORT_SOURCE GPIO_PortSourceGPIOD #define UP_BUTTON_EXTI_PIN_SOURCE GPIO_PinSource8 #define UP_BUTTON_EXTI_IRQn EXTI9_5_IRQn /** * @brief Joystick Down push-button */ #define DOWN_BUTTON_PIN GPIO_Pin_14 #define DOWN_BUTTON_GPIO_PORT GPIOD #define DOWN_BUTTON_GPIO_CLK RCC_APB2Periph_GPIOD #define DOWN_BUTTON_EXTI_LINE EXTI_Line14 #define DOWN_BUTTON_EXTI_PORT_SOURCE GPIO_PortSourceGPIOD #define DOWN_BUTTON_EXTI_PIN_SOURCE GPIO_PinSource14 #define DOWN_BUTTON_EXTI_IRQn EXTI15_10_IRQn /** * @brief Joystick Sel push-button */ #define SEL_BUTTON_PIN GPIO_Pin_12 #define SEL_BUTTON_GPIO_PORT GPIOD #define SEL_BUTTON_GPIO_CLK RCC_APB2Periph_GPIOD #define SEL_BUTTON_EXTI_LINE EXTI_Line12 #define SEL_BUTTON_EXTI_PORT_SOURCE GPIO_PortSourceGPIOD #define SEL_BUTTON_EXTI_PIN_SOURCE GPIO_PinSource12 #define SEL_BUTTON_EXTI_IRQn EXTI15_10_IRQn platform_config.h #ifdef USE_STM3210B_EVAL #define USB_DISCONNECT GPIOB ----->D改B #define USB_DISCONNECT_PIN GPIO_Pin_9 #define RCC_APB2Periph_GPIO_DISCONNECT RCC_APB2Periph_GPIOB ----->D改B #define EVAL_COM1_IRQHandler USART1_IRQHandler #elif defined (USE_STM3210E_EVAL) #define USB_DISCONNECT GPIOB #define USB_DISCONNECT_PIN GPIO_Pin_14 #define RCC_APB2Periph_GPIO_DISCONNECT RCC_APB2Periph_GPIOB #define EVAL_COM1_IRQHandler USART1_IRQHandler #elif defined (USE_STM3210C_EVAL) #define USB_DISCONNECT 0 #define USB_DISCONNECT_PIN 0 #define RCC_APB2Periph_GPIO_DISCONNECT 0 #define EVAL_COM1_IRQHandler USART2_IRQHandler main.c int main(void) { Set_System(); USB_Interrupts_Config();----------->程式卡死在這邊 Set_USBClock(); USB_Init(); while (1) { } } 請問我是哪邊沒修改到嗎?? |
STM32F401RBT6 USB 大容量存储设备问题
USB OTG 主机枚举问题
STM32F042 在启动文件内跳转至 USB DFU Bootloader
B-L475E-IOT01A 无法枚举为 USB DFU 设备
USBX Audio Class frame done 不触发回调
STM3210C-EVAL USB 官方例程调试报错
STM32F103 全速 USB 大容量存储方案咨询
STM32H573ZI 全速 USB
STM32F2xx 是否有 UVC 相关示例工程
USBX在F407上创建CDC不能正常使用
RE:USB Virtual COM Port的問題[急]
Set_USBClock();
USB_Init();
配置不通过,说明有一些代码是错误的。你仿真USB_Interrupts_Config();这个里面走到那一句死了?
回复:USB Virtual COM Port的問題[急]
把工程发出来看看,
Set_USBClock();
USB_Init();
我進去跑他是一直重複執行USB_Istr();
單步執行看他跑的情況是
void USB_Istr(void)
wIstr = _GetISTR();
#if (IMR_MSK & ISTR_SOF)
if (wIstr & ISTR_SOF & wInterrupt_Mask)
_SetISTR((uint16_t)CLR_SOF);
bIntPackSOF++;
#ifdef SOF_CALLBACK
SOF_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_CTR)
if (wIstr & ISTR_CTR & wInterrupt_Mask)
/* servicing of the endpoint correct transfer interrupt */
/* clear of the CTR flag into the sub */
CTR_LP();---------------------------------------------------------------------------------------->第一步
#ifdef CTR_CALLBACK
CTR_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_RESET)
if (wIstr & ISTR_RESET & wInterrupt_Mask)-------------------------------------------------->第二步
_SetISTR((uint16_t)CLR_RESET);
Device_Property.Reset();
#ifdef RESET_CALLBACK
RESET_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_DOVR)
if (wIstr & ISTR_DOVR & wInterrupt_Mask)
_SetISTR((uint16_t)CLR_DOVR);
#ifdef DOVR_CALLBACK
DOVR_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_ERR)
if (wIstr & ISTR_ERR & wInterrupt_Mask)
_SetISTR((uint16_t)CLR_ERR);
#ifdef ERR_CALLBACK
ERR_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_WKUP)
if (wIstr & ISTR_WKUP & wInterrupt_Mask)
_SetISTR((uint16_t)CLR_WKUP);
Resume(RESUME_EXTERNAL);
#ifdef WKUP_CALLBACK
WKUP_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_SUSP)
if (wIstr & ISTR_SUSP & wInterrupt_Mask)
/* check if SUSPEND is possible */
if (fSuspendEnabled)
Suspend();
else
/* if not possible then resume after xx ms */
Resume(RESUME_LATER);
/* clear of the ISTR bit must be done after setting of CNTR_FSUSP */
_SetISTR((uint16_t)CLR_SUSP);
#ifdef SUSP_CALLBACK
SUSP_Callback();
#endif
#endif
#if (IMR_MSK & ISTR_ESOF)
if (wIstr & ISTR_ESOF & wInterrupt_Mask)
_SetISTR((uint16_t)CLR_ESOF);
/* resume handling timing is made with ESOFs */
Resume(RESUME_ESOF); /* request without change of the machine state */
#ifdef ESOF_CALLBACK
ESOF_Callback();
#endif
#endif
}------------------------------------------------------------------------------------------------------------------->第三步
第二步到第三步之間都沒有進去就結束了,下一次再從第一步來,就這樣卡死在這
这个配置应该放在最后。
这个说明你的标志位不对,不看工程看不太明白,你把工程发出来。
这个配置应该放在最后。
我把整個專案貼上來,拜託大大幫我看看,小弟新手,完全靠自學
Virtual_COM_Port.rar
2011-10-15 00:20 上传
点击文件名下载附件
754.75 KB, 下载次数: 17
下载了,我这里好多错误解决不了。找不到你的文件。你应该先配置SUB,最好配置USB中断。
我再把連LIB都有的專案貼一次,我試過把USB_Init()加在USB_Interrupts_Config()之前就不會卡在那邊,是在設置USB中斷之前要先把USB INIT嗎??
è¤è£½ -STM32_USB-FS-Device_Lib_V3.3.0.rar
2011-10-18 09:33 上传
点击文件名下载附件
2.7 MB, 下载次数: 14
