LVGL的虚拟输入控件有button(按钮)、checkbox(复选框)、radiobox(单选框)、bar(直线拉条)和arc(弧形拉条)等,都可以通过这些输入控件的回调函数给MCU发送指令进而控制GPIO外设,而事件也有按下,抬起,按下+抬起,数值改变,状态改变等,这帖我就用arc+状态改变回调函数,实现弧形拉条控制PWM舵机的功能。 初始化TIM3为PWM输出功能,输出引脚为PC8,PC8接舵机PWM引脚: TIM_HandleTypeDef g_timx_pwm_chy_handle; void TIM3_PWM_Init(uint16_t arr, uint16_t psc) { GPIO_InitTypeDef gpio_init_struct; TIM_OC_InitTypeDef timx_oc_pwm_chy = {0}; __HAL_RCC_GPIOC_CLK_ENABLE(); __HAL_RCC_TIM3_CLK_ENABLE(); gpio_init_struct.Mode = GPIO_MODE_AF_PP; gpio_init_struct.Pull = GPIO_PULLUP; gpio_init_struct.Speed = GPIO_SPEED_FREQ_HIGH; gpio_init_struct.Alternate = GPIO_AF2_TIM3; gpio_init_struct.Pin = GPIO_PIN_8; HAL_GPIO_Init(GPIOC , &gpio_init_struct); g_timx_pwm_chy_handle.Instance = TIM3; g_timx_pwm_chy_handle.Init.Prescaler = psc; g_timx_pwm_chy_handle.Init.CounterMode = TIM_COUNTERMODE_UP; g_timx_pwm_chy_handle.Init.Period = arr; HAL_TIM_PWM_Init(&g_timx_pwm_chy_handle); timx_oc_pwm_chy.OCMode = TIM_OCMODE_PWM1; timx_oc_pwm_chy.Pulse = arr / 2; timx_oc_pwm_chy.OCPolarity = TIM_OCPOLARITY_LOW; HAL_TIM_PWM_ConfigChannel(&g_timx_pwm_chy_handle, &timx_oc_pwm_chy, TIM_CHANNEL_3); HAL_TIM_PWM_Start(&g_timx_pwm_chy_handle, TIM_CHANNEL_3); } 设置弧形拉条的参数和回调函数,弧形拉条位于tile_2界面即滑屏从左到右数起第二个界面的偏下方(LV_ALIGN_CENTER, 0 , 90),回调函数触发事件为拉条值改变(LV_EVENT_VALUE_CHANGED): void lv_example_tileview(void) { 。。。 arc_left = lv_arc_create(tile_2); lv_obj_set_size(arc_left , 200 , 200); lv_obj_align(arc_left , LV_ALIGN_CENTER, 0 , 90); lv_arc_set_value(arc_left , 66); lv_obj_set_style_arc_width(arc_left , 40 , LV_PART_MAIN); lv_obj_set_style_arc_width(arc_left , 40 , LV_PART_INDICATOR); lv_obj_add_event_cb(arc_left , arc_event_cb , LV_EVENT_VALUE_CHANGED, NULL); } 弧形拉条回调函数: static void arc_event_cb(lv_event_t *e) { int32_t val; lv_obj_t * target = (lv_obj_t *)lv_event_get_target(e); lv_event_code_t code = lv_event_get_code(e); if(code == LV_EVENT_VALUE_CHANGED) { val = lv_arc_get_value(target); printf("%d.\n" , val); TIM3->CCR3 = 10000 + 400 * val; } } 演示效果: 然后是使用SPI3接口控制一个NRF24L01模块进行发送,代码如下: SPI_HandleTypeDef g_spi3_handler; uint8_t SPI3_PC10_PC11_PC12_Read_Write_Byte(uint8_t txdata) { uint8_t rxdata; HAL_SPI_TransmitReceive(&g_spi3_handler , &txdata , &rxdata , 1 , 1000); return rxdata; } void SPI3_PC10_PC11_PC12_Init(void) { GPIO_InitTypeDef GPIO_InitStruct; RCC_PeriphCLKInitTypeDef rcc_periph_clk_init; __HAL_RCC_GPIOC_CLK_ENABLE(); __HAL_RCC_SPI3_CLK_ENABLE(); GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_PULLUP; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF6_SPI3; GPIO_InitStruct.Pin = GPIO_PIN_10 | GPIO_PIN_11 | GPIO_PIN_12; HAL_GPIO_Init(GPIOC , &GPIO_InitStruct); // rcc_periph_clk_init.PeriphClockSelection = RCC_PERIPHCLK_SPI3; // rcc_periph_clk_init.Spi123ClockSelection = RCC_SPI123CLKSOURCE_PLL; // HAL_RCCEx_PeriphCLKConfig(&rcc_periph_clk_init); g_spi3_handler.Instance = SPI3; g_spi3_handler.Init.Mode = SPI_MODE_MASTER; g_spi3_handler.Init.Direction = SPI_DIRECTION_2LINES; g_spi3_handler.Init.DataSize = SPI_DATASIZE_8BIT; g_spi3_handler.Init.CLKPolarity = SPI_POLARITY_LOW; g_spi3_handler.Init.CLKPhase = SPI_PHASE_1EDGE; g_spi3_handler.Init.NSS = SPI_NSS_SOFT; g_spi3_handler.Init.NSSPMode = SPI_NSS_PULSE_DISABLE; g_spi3_handler.Init.MasterKeepIOState = SPI_MASTER_KEEP_IO_STATE_ENABLE; g_spi3_handler.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_128; g_spi3_handler.Init.FirstBit = SPI_FIRSTBIT_MSB; g_spi3_handler.Init.TIMode = SPI_TIMODE_DISABLE; g_spi3_handler.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE; g_spi3_handler.Init.CRCPolynomial = 7; HAL_SPI_Init(&g_spi3_handler); __HAL_SPI_ENABLE(&g_spi3_handler); SPI3_PC10_PC11_PC12_Read_Write_Byte(0xff); } void NRF24L01_GPIO_Init(void) { GPIO_InitTypeDef gpio_init_struct; NRF24L01_CS_GPIO_CLK_ENABLE; NRF24L01_CE_GPIO_CLK_ENABLE; gpio_init_struct.Mode = GPIO_MODE_OUTPUT_PP; gpio_init_struct.Pull = GPIO_PULLUP; gpio_init_struct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; gpio_init_struct.Pin = NRF24L01_CS_GPIO_PIN; HAL_GPIO_Init(NRF24L01_CS_GPIO_PORT , &gpio_init_struct); gpio_init_struct.Pin = NRF24L01_CE_GPIO_PIN; HAL_GPIO_Init(NRF24L01_CE_GPIO_PORT , &gpio_init_struct); gpio_init_struct.Mode = GPIO_MODE_INPUT; gpio_init_struct.Pin = NRF24L01_IRQ_GPIO_PIN; HAL_GPIO_Init(NRF24L01_IRQ_GPIO_PORT , &gpio_init_struct); NRF24L01_CE_LOW; NRF24L01_CS_HIGH; } uint8_t NRF24L01_Write_Buf(uint8_t reg , uint8_t *pBuf , uint8_t len) { uint8_t status , u8_ctr; NRF24L01_CS_LOW; status = SPI3_PC10_PC11_PC12_Read_Write_Byte(reg); for(u8_ctr = 0 ; u8_ctr < len ; u8_ctr ++) SPI3_PC10_PC11_PC12_Read_Write_Byte(*pBuf++); NRF24L01_CS_HIGH; return status; } uint8_t NRF24L01_Read_Buf(uint8_t reg , uint8_t *pBuf , uint8_t len) { uint8_t status , u8_ctr; NRF24L01_CS_LOW; status = SPI3_PC10_PC11_PC12_Read_Write_Byte(reg); for(u8_ctr = 0 ; u8_ctr < len ; u8_ctr ++) pBuf[u8_ctr] = SPI3_PC10_PC11_PC12_Read_Write_Byte(0xff); NRF24L01_CS_HIGH; return status; } uint8_t NRF24L01_Write_Reg(uint8_t reg , uint8_t value) { uint8_t status; NRF24L01_CS_LOW; status = SPI3_PC10_PC11_PC12_Read_Write_Byte(reg); SPI3_PC10_PC11_PC12_Read_Write_Byte(value); NRF24L01_CS_HIGH; return(status); } uint8_t NRF24L01_Read_Reg(uint8_t reg) { uint8_t reg_val; NRF24L01_CS_LOW; SPI3_PC10_PC11_PC12_Read_Write_Byte(reg); reg_val = SPI3_PC10_PC11_PC12_Read_Write_Byte(0XFF); NRF24L01_CS_HIGH; return(reg_val); } NRF24L01的CS脚,CE脚,IRQ脚使用普通GPIO进行控制:
#define NRF24L01_1_CS_GPIO_PORT GPIOB #define NRF24L01_1_CS_GPIO_PIN GPIO_PIN_12 #define NRF24L01_1_CS_GPIO_CLK_ENABLE rcu_periph_clock_enable(RCU_GPIOB); #define NRF24L01_1_CS_HIGH GPIO_BOP(NRF24L01_1_CS_GPIO_PORT) = NRF24L01_1_CS_GPIO_PIN; #define NRF24L01_1_CS_LOW GPIO_BC(NRF24L01_1_CS_GPIO_PORT) = NRF24L01_1_CS_GPIO_PIN; #define NRF24L01_1_CE_GPIO_PORT GPIOB #define NRF24L01_1_CE_GPIO_PIN GPIO_PIN_10 #define NRF24L01_1_CE_GPIO_CLK_ENABLE rcu_periph_clock_enable(RCU_GPIOB); #define NRF24L01_1_CE_HIGH GPIO_BOP(NRF24L01_1_CE_GPIO_PORT) = NRF24L01_1_CE_GPIO_PIN; #define NRF24L01_1_CE_LOW GPIO_BC(NRF24L01_1_CE_GPIO_PORT) = NRF24L01_1_CE_GPIO_PIN; #define NRF24L01_1_IRQ_GPIO_PORT GPIOB #define NRF24L01_1_IRQ_GPIO_PIN GPIO_PIN_11 #define NRF24L01_1_IRQ_GPIO_CLK_ENABLE rcu_periph_clock_enable(RCU_GPIOB); #define NRF24L01_1_IRQ_READ gpio_input_bit_get(NRF24L01_1_IRQ_GPIO_PORT , NRF24L01_1_IRQ_GPIO_PIN) 在lv_timer定时器回调函数中进行无线发送: static void my_timer1(lv_timer_t * timer) { 。。。 nrf_buf[0] = 0xaa; nrf_buf[1] = 0xbb; nrf_buf[2] = 2; nrf_buf[3] = (bme680fd.temperature >> 8) & 0xff; nrf_buf[4] = bme680fd.temperature & 0xff; nrf_buf[5] = (bme680fd.pressure >> 24) & 0xff; nrf_buf[6] = (bme680fd.pressure >> 16) & 0xff; nrf_buf[7] = (bme680fd.pressure >> 8) & 0xff; nrf_buf[8] = bme680fd.pressure & 0xff; nrf_buf[9] = (bme680fd.humidity >> 24) & 0xff; nrf_buf[10] = (bme680fd.humidity >> 16) & 0xff; nrf_buf[11] = (bme680fd.humidity >> 8) & 0xff; nrf_buf[12] = bme680fd.humidity & 0xff; nrf_buf[30] = 0xcc; nrf_buf[31] = 0**; if(NRF24L01_TxPacket(nrf_buf) == TX_OK) { printf("NRF24L01_TxPacket succeed.\n"); } else { printf("NRF24L01_TxPacket failed.\n"); } 。。。 } 演示效果,使用另外一块MCU板接上另一个NRF24L01模块进行轮询接收:
STM32L562DK探索板——测试小结
STM32 GUI 图形方案,带你解锁嵌入式界面开发新思路
STM32L562DK探索板——给Audio Play添加音量控制功能
STM32L562DK探索板——Audio Play使用的疑惑
4-开发生态篇:TouchGFX+STM32Cube 一站式 GUI 落地流程
3-产品选型篇:全系列 STM32 GUI 专用 MCU 分级选型表
2-架构革新篇:STM32单芯片嵌入式GUI核心技术原理与性能优势
STM32L562DK探索板——重写Led闪烁demo
STM32L562DK探索板——触摸菜单的实验
STM32L562DK探索板——简单的显示变量函数
