STM32F407VG Bootloader 跳转异常
patch1582 提问时间:2026-7-13 15:06 / 未解决
我正在编写 Bootloader,参考了论坛大量帖子完成跳转代码。 如果注释掉固件升级函数PerformFirmwareUpdate(),跳转运行完全正常。 typedef void (*pFunction)(void); pFunction appEntry;
uint32_t appStack;
HAL_Init();
/ Get the application stack pointer (First entry in the application vector table) /
appStack = (uint32_t) ((__IO uint32_t)EXEC_ZONE_ADDR);
/ Get the application entry point (Second entry in the application vector table) /
appEntry = (pFunction) (__IO uint32_t) (EXEC_ZONE_ADDR);// + 4);
if (CheckFirmwareUpdate)
//PerformFirmwareUpdate();
HAL_DeInit();
/ Reconfigure vector table offset register to match the application location /
SCB->VTOR = EXEC_ZONE_ADDR;
/ Set the application stack pointer /
__disable_irq();
__set_MSP(appStack);
__DSB();
/ Start the application /
appEntry();
when i uncomment the function which copies the program in the execution sector (5), then i get the problem:
the appEntry gets the value of sector 6 instead of sector 5 which is the real value assigned.
void PerformFirmwareUpdate(void)
{ if (FlashErase(FLASH_SECTOR_5))//(FLASH_SECTOR_5); { uint32_t data_ptr = (uint32_t )PROG_ZONE_ADDR; HAL_FLASH_Unlock(); for(uint32_t i = 0; i < (SECTOR_SIZE); i += sizeof(uint32_t), data_ptr++ ) { if(HAL_FLASH_Program(FLASH_TYPEPROGRAM_WORD, EXEC_ZONE_ADDR + i, *data_ptr) != HAL_OK) { //WORD = 32bits break; } FLASH_WaitForLastOperation (4000); //in ms, max time to erase whole sector; see datasheet } HAL_FLASH_Lock(); } return; }
收藏 评论4 发布时间:2026-7-13 15:06
4个回答
butterflyspring 回答时间:2026-7-13 16:11:14
这个型号的升级代码,在库里面都有现成的呀。
现在的小伙伴们都参照甚至直接用的。
经典型号哦,都用了十多年了。
废鱼 回答时间:2026-7-14 15:37:01
如果注释掉PerformFirmwareUpdate可以正常运行,说明PerformFirmwareUpdate的代码 有问题。在操作FLASH前,需要先解锁FLASH,建议参考FLASH的完整操作DEMO进行修改。
patch1582 回答时间:2026-7-21 17:05:17
butterflyspring 发表于 2026-7-13 16:11
这个型号的升级代码,在库里面都有现成的呀。</p>
<p>现在的小伙伴们都参照甚至直接用的。
我也是,之前的代码在前公司,现在要重新实现
patch1582 回答时间:2026-7-21 17:05:51
废鱼 发表于 2026-7-14 15:37
如果注释掉PerformFirmwareUpdate可以正常运行,说明PerformFirmwareUpdate的代码 有问题。在操作FLASH ...
[md]流程没找到问题,肯定在代码中有瑕疵
