stm32u575 gpdma burst length配置为8 定时器update触发fmc操作外部adc芯片ads8588不成功,根本不触发,burst length配置为1能触发但是单次触发 跪求大神指点,感激涕零!我需要burst功能一次timeupdate 触发8次dma操作搬运8路adc数据到内存,谢谢! 配置及其代码如下: __HAL_RCC_TIM3_CLK_ENABLE(); /* TIM3 DMA Init */ /* GPDMA1_REQUEST_TIM3_UP Init */ handle_GPDMA1_Channel13.Instance = GPDMA1_Channel13; handle_GPDMA1_Channel13.Init.Request = GPDMA1_REQUEST_TIM3_UP; handle_GPDMA1_Channel13.Init.BlkHWRequest = DMA_BREQ_SINGLE_BURST; handle_GPDMA1_Channel13.Init.Direction = DMA_PERIPH_TO_MEMORY; handle_GPDMA1_Channel13.Init.SrcInc = DMA_SINC_FIXED; handle_GPDMA1_Channel13.Init.DestInc = DMA_DINC_INCREMENTED; handle_GPDMA1_Channel13.Init.SrcDataWidth = DMA_SRC_DATAWIDTH_HALFWORD; handle_GPDMA1_Channel13.Init.DestDataWidth = DMA_DEST_DATAWIDTH_HALFWORD; handle_GPDMA1_Channel13.Init.Priority = DMA_LOW_PRIORITY_HIGH_WEIGHT; handle_GPDMA1_Channel13.Init.SrcBurstLength = 8; handle_GPDMA1_Channel13.Init.DestBurstLength = 8; handle_GPDMA1_Channel13.Init.TransferAllocatedPort = DMA_SRC_ALLOCATED_PORT0|DMA_DEST_ALLOCATED_PORT0; handle_GPDMA1_Channel13.Init.TransferEventMode = DMA_TCEM_BLOCK_TRANSFER; handle_GPDMA1_Channel13.Init.Mode = DMA_NORMAL; if (HAL_DMA_Init(&handle_GPDMA1_Channel13) != HAL_OK) { Error_Handler(); } __HAL_LINKDMA(htim_base, hdma[TIM_DMA_ID_UPDATE], handle_GPDMA1_Channel13); if (HAL_DMA_ConfigChannelAttributes(&handle_GPDMA1_Channel13, DMA_CHANNEL_NPRIV) != HAL_OK) { Error_Handler(); } /* TIM3 interrupt Init */ HAL_NVIC_SetPriority(TIM3_IRQn, 3, 0); HAL_NVIC_EnableIRQ(TIM3_IRQn); void start_ads8588s_convert222(void) { //1、开启pwm convert 开始转换 __HAL_RCC_GPDMA1_CLK_ENABLE(); //HAL_TIM_Base_MspDeInit(&htim3); tim3_reinit(); pwm_OutPut(); //PWM输出映射到io HAL_TIM_Base_Start_IT(&htim3); if (HAL_TIM_PWM_Start(&htim3, TIM_CHANNEL_4) != HAL_OK) { Error_Handler(); } HAL_Delay(2); //2、使能DMA传输 __HAL_DMA_ENABLE_IT(&handle_GPDMA1_Channel13, DMA_IT_TC); __HAL_DMA_DISABLE_IT(&handle_GPDMA1_Channel13,DMA_IT_HT); /* 使能定时器中断 */ __HAL_TIM_ENABLE_DMA(&htim3, TIM_DMA_UPDATE); __HAL_TIM_CLEAR_FLAG(&htim3, TIM_FLAG_UPDATE); //3、开始采集数据 操作FMC总线 HAL_DMA_Start_IT(&handle_GPDMA1_Channel13, (u32)Bank1_BASE1, (u32)g_adcBuf, ADC_BUFSIZE); } 上图的SrcBurstLength改为1 DestBurstLenth改为1 能单次触发 一但改为其他不行 谢谢 |
串口DMA收发出现ORE错误
STM32F3系列SDADC外部触发 DMA运输的bug
STM32U575 TrustZone 工程中断异常
HAL_TIM_OC_SetConfigChannel 因 override_state 参数触发断言报错
在 STM32Cube 中配置正交编码器模式
stm32H723 tim23和tim24 中间对齐模式无效
stm32H723 tim23和tim24是不是不支持中间对齐模式?
用电位器调节 PWM 频率
求问诡异的问题,eth网口ping不通
请问一下STM32U575VGT6在mx里怎么配置DCMI的DMA setting啊,我点那个页面只有GPDMA1,跳转过去也没有什么DCMI的选项
如果是FMC接口的话,那么源地址应该是多个的吧,不应该是 “DMA_SINC_FIXED”
