#include "main.h" #include "dma.h" #include "i2s.h" #include "usart.h" #include "usb_device.h" #include "gpio.h" #include "FIFO.h" #include "usbd_cdc_if.h" uint32_t dma[4]; uint32_t val24[2]; int val32[2]; fifo_s_t *g_i2s_dma_recv_fifo = NULL; void SystemClock_Config(void); void HAL_I2S_RxCpltCallback(I2S_HandleTypeDef *hi2s) { if(hi2s==&hi2s1){ for(int i=0;i < 2;i++){ val24=(dma[2*i]<<8)+(dma[2*i+1]>>8); if(val24 & 0x800000){//negative val32=0xff000000 | val24; }else{//positive val32=val24; } } if (!fifo_s_isfull(g_i2s_dma_recv_fifo)) { fifo_s_puts(g_i2s_dma_recv_fifo, (char*)val32, sizeof(val32)); } } } int main(void) { HAL_Init(); SystemClock_Config(); MX_GPIO_Init(); MX_DMA_Init(); MX_I2S1_Init(); MX_USB_DEVICE_Init(); MX_USART1_UART_Init(); if (g_i2s_dma_recv_fifo != NULL) { fifo_s_destroy(g_i2s_dma_recv_fifo); } g_i2s_dma_recv_fifo = fifo_s_create(480); if (!g_i2s_dma_recv_fifo) { printf("fifo cre failed.\n"); return -1; } HAL_I2S_Receive_DMA(&hi2s1, (uint16_t *)dma, 4); while (1) { /* USER CODE END WHILE */ if (!fifo_s_isempty(g_i2s_dma_recv_fifo)) { char res[16] = {'\0'}; if (fifo_s_gets(g_i2s_dma_recv_fifo, res, sizeof(res)) > 0) { CDC_Transmit_FS((uint8_t*)res, sizeof(res)); } } /* USER CODE BEGIN 3 */ } /* USER CODE END 3 */ } void SystemClock_Config(void) { RCC_OscInitTypeDef RCC_OscInitStruct = {0}; RCC_ClkInitTypeDef RCC_ClkInitStruct = {0}; /** Configure the main internal regulator output voltage */ __HAL_RCC_PWR_CLK_ENABLE(); __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1); RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE; RCC_OscInitStruct.HSEState = RCC_HSE_ON; RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON; RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE; RCC_OscInitStruct.PLL.PLLM = 15; RCC_OscInitStruct.PLL.PLLN = 144; RCC_OscInitStruct.PLL.PLLP = RCC_PLLP_DIV4; RCC_OscInitStruct.PLL.PLLQ = 5; if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) { Error_Handler(); } /** Initializes the CPU, AHB and APB buses clocks */ RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2; RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK; RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2; RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1; if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK) { Error_Handler(); } } void Error_Handler(void) { __disable_irq(); while (1) { } /* USER CODE END Error_Handler_Debug */ } #ifdef USE_FULL_ASSERT void assert_failed(uint8_t *file, uint32_t line) { } #endif /* USE_FULL_ASSERT */ |
STM32F407VET6,使用cubeIDE下载跑不起来
FLASH擦除轮询等待时CPU真的会轮询吗
STM32F417 RTC读取亚秒寄存器
串口DMA收发出现ORE错误
STM32F3系列SDADC外部触发 DMA运输的bug
STM32F405ZGT6 批次22+ 问下这颗料,60度烘烤12小时后,出现鼓包,是怎么回事? 原厂有标准的烘烤温度范围 跟时长范围吗?
非官方开发板第一次下载成功,之后就各种失败
STM32H5F/E 相比 STM32F4 系列最大的优势是什么?
ST TOF问题请教
