SEGGER J-Link GDB Server V7.92n Command Line Version JLinkARM.dll V7.92n (DLL compiled Oct 31 2023 15:10:15) Command line: -port 2331 -s -device STM32WBA52CG -endian little -speed 4000 -if swd -vd -----GDB Server start settings----- GDBInit file: none GDB Server Listening port: 2331 SWO raw output listening port: 2332 Terminal I/O port: 2333 Accept remote connection: localhost only Generate logfile: off Verify download: on Init regs on start: off Silent mode: off Single run mode: on Target connection timeout: 0 ms ------J-Link related settings------ J-Link Host interface: USB J-Link script: none J-Link settings file: none ------Target related settings------ Target device: STM32WBA52CG Target device parameters: none Target interface: SWD Target interface speed: 4000kHz Target endian: little Connecting to J-Link... J-Link is connected. Firmware: J-Link V9 compiled May 7 2021 16:26:12 Hardware: V9.50 S/N: 69532295 Feature(s): JFlash, GDB, RDI, FlashBP, FlashDL Checking target voltage... Target voltage: 3.32 V Listening on TCP/IP port 2331 Connecting to target... Halting core... Core security extensions: Not implemented Connected to target Waiting for GDB connection...Connected to 0000:0000:0000:0000:0000:0000:0000:0001 GDB client (conn. 944) requested target.xml from GDB Server Reading common registers: Read register 'r0' (4 bytes) from hardware: 0x07000000 Read register 'r1' (4 bytes) from hardware: 0x00000000 Read register 'r2' (4 bytes) from hardware: 0x01000000 Read register 'r3' (4 bytes) from hardware: 0x01000000 Read register 'r4' (4 bytes) from hardware: 0xF8040020 Read register 'r5' (4 bytes) from hardware: 0x44050020 Read register 'r6' (4 bytes) from hardware: 0x0000000C Read register 'r7' (4 bytes) from hardware: 0x74FF0120 Read register 'r8' (4 bytes) from hardware: 0xFFFFFFFF Read register 'r9' (4 bytes) from hardware: 0xD8050040 Read register 'r10' (4 bytes) from hardware: 0xFFFFFFFF Read register 'r11' (4 bytes) from hardware: 0xFFFFFFFF Read register 'r12' (4 bytes) from hardware: 0x54020106 Read register 'sp' (4 bytes) from hardware: 0x74FF0120 Read register 'lr' (4 bytes) from hardware: 0xD5BE0408 Read register 'pc' (4 bytes) from hardware: 0x50CA0408 Read register 'xpsr' (4 bytes) from hardware: 0x00000001 Read 4 bytes @ address 0x0804CA50 (Data = 0x681B4B05) Received monitor command: ReadAPEx 0x1000000 0xF8 O.K.:0xE00FE003 Read 4 bytes @ address 0xE000EE08 (Data = 0x00000000) Received monitor command: ReadMemAP 0x1000000 0xE00FEFD0 0x8 0x0 O.K.:0x00000000,0x00000000,0x00000000,0x00000000,0x00000092,0x00000004,0x0000000A,0x00000000 Reading register 'msp' = 0x2001FF74 Reading register 'psp' = 0x00000000 Read 4 bytes @ address 0x0804BED4 (Data = 0xBD80BF00) Reading 64 bytes @ address 0x2001FF40 Connected to 0000:0000:0000:0000:0000:0000:0000:0001 Read 4 bytes @ address 0x080589C4 (Data = 0x60FB69FB) GDB client (conn. 964) requested target.xml from GDB Server Reading 64 bytes @ address 0x2001FFC0 Read 4 bytes @ address 0x0804BEC0 (Data = 0xBD80BF00) Reading common registers: Read register 'r0' (4 bytes) from hardware: 0x07000000 Read register 'r1' (4 bytes) from hardware: 0x00000000 Read register 'r2' (4 bytes) from hardware: 0x01000000 Read register 'r3' (4 bytes) from hardware: 0x01000000 Read register 'r4' (4 bytes) from hardware: 0xF8040020 Read register 'r5' (4 bytes) from hardware: 0x44050020 Read register 'r6' (4 bytes) from hardware: 0x0000000C Read register 'r7' (4 bytes) from hardware: 0x74FF0120 Read register 'r8' (4 bytes) from hardware: 0xFFFFFFFF Read register 'r9' (4 bytes) from hardware: 0xD8050040 Read register 'r10' (4 bytes) from hardware: 0xFFFFFFFF Read register 'r11' (4 bytes) from hardware: 0xFFFFFFFF Read register 'r12' (4 bytes) from hardware: 0x54020106 Read register 'sp' (4 bytes) from hardware: 0x74FF0120 Read register 'lr' (4 bytes) from hardware: 0xD5BE0408 Read register 'pc' (4 bytes) from hardware: 0x50CA0408 Read register 'xpsr' (4 bytes) from hardware: 0x00000001 Read 4 bytes @ address 0x0804BFC6 (Data = 0xB580E7FC) Read 4 bytes @ address 0x0804CA50 (Data = 0x681B4B05) Downloading 348 bytes @ address 0x08000000 - Verified OK Downloading 16148 bytes @ address 0x0800015C - Verified OK Downloading 16192 bytes @ address 0x08004070 - Verified OK Downloading 16272 bytes @ address 0x08007FB0 - Verified OK Downloading 16064 bytes @ address 0x0800BF40 - Verified OK Downloading 16144 bytes @ address 0x0800FE00 - Verified OK Downloading 16224 bytes @ address 0x08013D10 - Verified OK Downloading 16208 bytes @ address 0x08017C70 - Verified OK Downloading 16112 bytes @ address 0x0801BBC0 - Verified OK Downloading 16144 bytes @ address 0x0801FAB0 - Verified OK Downloading 16128 bytes @ address 0x080239C0 - Verified OK Downloading 16096 bytes @ address 0x080278C0 - Verified OK Downloading 16160 bytes @ address 0x0802B7A0 - Verified OK Downloading 16176 bytes @ address 0x0802F6C0 - Verified OK Downloading 16192 bytes @ address 0x080335F0 - Verified OK Downloading 16224 bytes @ address 0x08037530 - Verified OK Downloading 16208 bytes @ address 0x0803B490 - Verified OK Downloading 16160 bytes @ address 0x0803F3E0 - Verified OK Downloading 16176 bytes @ address 0x08043300 - Verified OK Downloading 16176 bytes @ address 0x08047230 - Verified OK Downloading 16048 bytes @ address 0x0804B160 - Verified OK Downloading 16000 bytes @ address 0x0804F010 - Verified OK Downloading 16048 bytes @ address 0x08052E90 - Verified OK Downloading 9076 bytes @ address 0x08056D40 - Verified OK Downloading 11780 bytes @ address 0x080590B8 - Verified OK Downloading 8 bytes @ address 0x0805BEBC - Verified OK Downloading 4 bytes @ address 0x0805BEC4 - Verified OK Downloading 4 bytes @ address 0x0805BEC8 - Verified OK Downloading 1272 bytes @ address 0x0805BECC - Verified OK Writing register 'pc' = 0x080585F0 Read 4 bytes @ address 0x080585F0 (Data = 0x46854828) Read 2 bytes @ address 0x080585F0 (Data = 0x4828) Starting target CPU... GDB closed TCP/IP connection (Socket 964) Debugger requested to halt target... ...Target halted (PC = 0x0804C398) Reading common registers: Read register 'r0' (4 bytes) from hardware: 0x03000000 Read register 'r1' (4 bytes) from hardware: 0x00080246 Read register 'r2' (4 bytes) from hardware: 0x0030020F Read register 'r3' (4 bytes) from hardware: 0x03000000 Read register 'r4' (4 bytes) from hardware: 0xF8040020 Read register 'r5' (4 bytes) from hardware: 0x44050020 Read register 'r6' (4 bytes) from hardware: 0x0000000C Read register 'r7' (4 bytes) from hardware: 0x64FF0120 Read register 'r8' (4 bytes) from hardware: 0xFFFFFFFF Read register 'r9' (4 bytes) from hardware: 0xD8050040 Read register 'r10' (4 bytes) from hardware: 0xFFFFFFFF Read register 'r11' (4 bytes) from hardware: 0xFFFFFFFF Read register 'r12' (4 bytes) from hardware: 0x54020106 Read register 'sp' (4 bytes) from hardware: 0x64FF0120 Read register 'lr' (4 bytes) from hardware: 0xF9BF0408 Read register 'pc' (4 bytes) from hardware: 0x98C30408 Read register 'xpsr' (4 bytes) from hardware: 0x00000021 Read 4 bytes @ address 0x0804C398 (Data = 0x0000E7FE) GDB closed TCP/IP connection (Socket 944) Restoring target state and closing J-Link connection... Shutting down... 因为STLINKV2连接不上换成了JLINK,可以用J-Flash连接上去,并进行擦片。但是在使用CubeIDE进行调试的时候,无法进入调试状态。 以上信息是进入调试时候的打印信息,不明白在下面这个信息后 Halting core... Core security extensions: Not implemented 为什么会跳转TCP/IP这样的连接,还有这个地方突然停止核心,一般是什么原因? 用CubeIDE,我应该是可以把程序下载进入,因为我重新上电之后,可以扫描看到BLE的广播名称,并且手机能够进行配对。 |
在stm32cuide中打不开stm32cubemx
关于stm32cubeide下载问题
SDIO读取TF卡,1bit模式正常,4bit模式无法读取
端午节 了
离线安装帮助插件
STM32U385的PB1引脚设置推挽输出,外部接电阻上拉时,断掉MCU的电源,MCU仍然运行的问题
新版本STM32CUBEIDE在新建工程中无法没有CUBEMX的选项了?
STM32CubeIDE for Visual Studio Code无法使用
STM32 CubeIDE 中的编译器优化等级
显示签到成功,但是并没有,积分没有增加,签到按钮也没有显示已签到。
