Bluetooth® Low Energy 5.0 and 802.15.4 module,ES0525: STM32WB5MMG module product
STMCU小助手 发布时间:2022-11-12 16:21
1 Introduction
This datasheet provides the ordering information and mechanical device characteristics of the STM32WB5MMGmodule.
This document should be read in conjunction with the Multiprotocol wireless 32-bit MCU Arm®-based Cortex®-M4with FPU, Bluetooth® 5.3 and 802.15.4 radio solution (DS11929) and Multiprotocol wireless 32-bit MCU Arm®-based Cortex®-M4 with FPU, Bluetooth® Low Energy and 802.15.4 radio solution (RM0434). Both documents areavailable from the STMicroelectronics website .
For information on the Arm® Cortex® cores, refer to the Cortex® Technical Reference Manual, available from the website
Note: Arm is a registered trademark of Arm Limited (or its subsidiaries) in the US and/or elsewhere.
2 Description
The STM32WB5MMG is an ultra-low-power and small form factor certified 2.4 GHz wireless module. Itsupports Bluetooth® Low Energy 5.3, Zigbee® 3.0, OpenThread, dynamic and static concurrent modes, and802.15.4 proprietary protocols. Based on STMicroelectronics STM32WB55VGY wireless microcontroller, theSTM32WB5MMG provides best-in-class RF performance thanks to its good receiver sensitivity and a highoutput power signal. Its low-power features enable extended battery life time, small coin-cell batteries or energyharvesting.
STM32WB5MMG revision Y is based on cut 2.1 of the STM32WB55VGY microcontroller. Revision X is based oncut 2.2.
The STM32WB5MMG requires no RF expertise and is the best way to speed-up any development and to reduceassociated costs. The module is completely protocol stack royalty-free.
3 Module overview
The module is an SiP-LGA86 package (system in package land grid array) that integrates the provenSTM32WB55VGY MCU with several external components. The package includes:
• LSE crystal
• HSE crystal
• Passive components for SMPS
• Antenna matching and antenna
• IPD for RF matching and harmonics rejection
3.1 Versions
The STM32WB5MMG is shipped in two finished goods versions. In this datasheet they are referred to as versions X and Y. X is the more recent version. The product version is identified by the package marking with X or Y as shown in Section 9.1.1 Device marking for SiP-LGA86.
3.2 Power supply
The power supply requirements are identical to regular STM32WB55xx and described in the datasheet. Filtering capacitors on power supply pins and components for the SMPS are already integrated into the module.
3.2.1 SMPS
SMPS can be set to either ON or in BYPASS mode. The integrated passive components are for SMPS operation running at 4MHz. For additional information on the SMPS, check the reference manual or the application note Usage of SMPS on STM32WB Series microcontroller (AN5246).
完整版请查看:附件
en.DM00686226.pdf
7.05 MB, 下载次数: 1
收藏 评论0 发布时间:2022-11-12 16:21
