发布时间:2022-7-1 13:11
在前面推文的介绍中,我们知道STM32系统复位后首先进入SystemInit函数进行时钟的设置,然后进入主函数main。那么我们就来看下SystemInit()函数到底做了哪些操作,首先打开我们前面使用库函数编写的LED程序,在system_stm32f10x.c文件中可以找到SystemInit()函数,SystemInit()代码如下: void SystemInit (void) { /* Reset the RCC clock configuration to the default reset state(for debug purpose) */ /* Set HSION bit */ RCC->CR |= (uint32_t)0x00000001; /* Reset SW, HPRE, PPRE1, PPRE2, ADCPRE and MCO bits */ #ifndef STM32F10X_CL RCC->CFGR &= (uint32_t)0xF8FF0000; #else RCC->CFGR &= (uint32_t)0xF0FF0000; #endif /* STM32F10X_CL */ /* Reset HSEON, CSSON and PLLON bits */ RCC->CR &= (uint32_t)0xFEF6FFFF; /* Reset HSEBYP bit */ RCC->CR &= (uint32_t)0xFFFBFFFF; /* Reset PLLSRC, PLLXTPRE, PLLMUL and USBPRE/OTGFSPRE bits */ RCC->CFGR &= (uint32_t)0xFF80FFFF; #ifdef STM32F10X_CL /* Reset PLL2ON and PLL3ON bits */ RCC->CR &= (uint32_t)0xEBFFFFFF; /* Disable all interrupts and clear pending bits */ RCC->CIR = 0x00FF0000; /* Reset CFGR2 register */ RCC->CFGR2 = 0x00000000; #elif defined (STM32F10X_LD_VL) || defined (STM32F10X_MD_VL) || (defined STM32F10X_HD_VL) /* Disable all interrupts and clear pending bits */ RCC->CIR = 0x009F0000; /* Reset CFGR2 register */ RCC->CFGR2 = 0x00000000; #else /* Disable all interrupts and clear pending bits */ RCC->CIR = 0x009F0000; #endif /* STM32F10X_CL */ #if defined (STM32F10X_HD) || (defined STM32F10X_XL) || (defined STM32F10X_HD_VL) #ifdef DATA_IN_ExtSRAM SystemInit_ExtMemCtl(); #endif /* DATA_IN_ExtSRAM */ #endif /* Configure the System clock frequency, HCLK, PCLK2 and PCLK1 prescalers */ /* Configure the Flash Latency cycles and enable prefetch buffer */ SetSysClock(); #ifdef VECT_TAB_SRAM SCB->VTOR = SRAM_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal SRAM. */ #else SCB->VTOR = FLASH_BASE | VECT_TAB_OFFSET; /* Vector Table Relocation in Internal FLASH. */ #endif } SystemInit函数开始通过条件编译, 先复位RCC寄存器,同时通过设置CR寄存器的HSI时钟使能位来打开HSI时钟。默认情况下如果CR寄存器复位,是选择HSI作为系统时钟,这点大家可以查看RCC->CR寄存器相关位描述可以得知,当低两位配置为00的时候(复位之后),会选择HSI振荡器为系统时钟。也就是说,调用SystemInit函数之后,首先是选择HSI作为系统时钟。在设置完相关寄存器后才换成HSE作为系统时钟,接下来SystemInit函数内部会调用SetSysClock()函数。这个函数内部是根据宏定义设置系统时钟频率。函数如下: static void SetSysClock(void) { #ifdef SYSCLK_FREQ_HSE SetSysClockToHSE(); #elif defined SYSCLK_FREQ_24MHz SetSysClockTo24(); #elif defined SYSCLK_FREQ_36MHz SetSysClockTo36(); #elif defined SYSCLK_FREQ_48MHz SetSysClockTo48(); #elif defined SYSCLK_FREQ_56MHz SetSysClockTo56(); #elif defined SYSCLK_FREQ_72MHz SetSysClockTo72(); #endif } 在system_stm32f10x.c文件的开头就有对此宏定义,系统默认的宏定义是72MHz,如下: #define SYSCLK_FREQ_72MHz 72000000 如果你要设置为36MHz,只需要注释掉上面代码,然后加入下面代码即可: #define SYSCLK_FREQ_36MHz 36000000 根据该函数内部实现过程可知,直接调用SetSysClockTo72()函数,此函数功能是将系统时钟SYSCLK设置为72M,AHB总线时钟设置为72M,APB2总线时钟设置为72M,APB1总线时钟设置为36M,PLL时钟设置为72M。函数具体实现大家可以打开库函数查看,这里我们就不截取出来。如果SystemInit内实现过程看不懂没有关系,大家只要知道SystemInit函数执行完,时钟大小设置如下: SYSCLK(系统时钟) =72MHz AHB 总线时钟(HCLK=SYSCLK) =72MHz APB1 总线时钟(PCLK1=SYSCLK/2) =36MHz APB2 总线时钟(PCLK2=SYSCLK/1) =72MHz PLL 主时钟 =72MHz 在STM32中,这些时钟值是要熟悉的。 |
使用STM32 MCU和MPU连接PDM数字麦克风
好用软件推荐-TouchGFX Designer
HRTIM 指南
使用 STM32 的 DWT 单元监控内存
DAC,COMP,HRTIM Fault 功能的使用
一个软件引起的 LSE 驱动不良的问题
