你好, 我有開個專案MCU選用的是STM32F091CBTx 包含CANBUS的應用, 直接下載到在NUCLEO64(STM32F091RC)的時候,CAN_TX (PA12)是可以發出CAN的訊息出來 可是當我把同一個專案直接下載到STM32F091CBTx應用板上的時候,CAN_TX (PA12)發出CAN的訊息卻是不正確的 請問一下,這是什麼原因 程式碼如下 /* CAN init function */ void MX_CAN_Init(void) { CAN_FilterConfTypeDef sFilterConfig; hcan.Instance = CAN; hcan.Init.Prescaler = 3; hcan.Init.Mode = CAN_MODE_NORMAL; hcan.Init.SJW = CAN_SJW_1TQ; hcan.Init.BS1 = CAN_BS1_10TQ; hcan.Init.BS2 = CAN_BS2_4TQ; hcan.Init.TTCM = DISABLE; hcan.Init.ABOM = ENABLE; hcan.Init.AWUM = DISABLE; hcan.Init.NART = DISABLE; hcan.Init.RFLM = DISABLE; hcan.Init.TXFP = DISABLE; if (HAL_CAN_Init(&hcan) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } sFilterConfig.FilterNumber = 0; sFilterConfig.FilterMode = CAN_FILTERMODE_IDMASK; sFilterConfig.FilterScale = CAN_FILTERSCALE_32BIT; sFilterConfig.FilterIdHigh = 0x0000; sFilterConfig.FilterIdLow = 0x0000; sFilterConfig.FilterMaskIdHigh = 0x0000; sFilterConfig.FilterMaskIdLow = 0x0000; sFilterConfig.FilterFIFOAssignment = 0; sFilterConfig.FilterActivation = ENABLE; sFilterConfig.BankNumber = 0; HAL_CAN_ConfigFilter(&hcan, &sFilterConfig); } //========================================== void HAL_CAN_MspInit(CAN_HandleTypeDef* canHandle) { GPIO_InitTypeDef GPIO_InitStruct; if(canHandle->Instance==CAN) { /* USER CODE BEGIN CAN_MspInit 0 */ /* USER CODE END CAN_MspInit 0 */ /* CAN clock enable */ /**CAN GPIO Configuration PA11 ------> CAN_RX PA12 ------> CAN_TX */ GPIO_InitStruct.Pin = GPIO_PIN_11|GPIO_PIN_12; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_PULLUP; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH; GPIO_InitStruct.Alternate = GPIO_AF4_CAN; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); __HAL_RCC_CAN1_CLK_ENABLE(); /* CAN interrupt Init */ HAL_NVIC_SetPriority(CEC_CAN_IRQn, 0, 0); HAL_NVIC_EnableIRQ(CEC_CAN_IRQn); /* USER CODE BEGIN CAN_MspInit 1 */ /* USER CODE END CAN_MspInit 1 */ } } void HAL_CAN_MspDeInit(CAN_HandleTypeDef* canHandle) { if(canHandle->Instance==CAN) { /* USER CODE BEGIN CAN_MspDeInit 0 */ /* USER CODE END CAN_MspDeInit 0 */ /* Peripheral clock disable */ __HAL_RCC_CAN1_CLK_DISABLE(); /**CAN GPIO Configuration PA11 ------> CAN_RX PA12 ------> CAN_TX */ HAL_GPIO_DeInit(GPIOA, GPIO_PIN_11|GPIO_PIN_12); /* CAN interrupt Deinit */ HAL_NVIC_DisableIRQ(CEC_CAN_IRQn); /* USER CODE BEGIN CAN_MspDeInit 1 */ /* USER CODE END CAN_MspDeInit 1 */ } } //=================================================== int main(void) { /* USER CODE BEGIN 1 */ /* USER CODE END 1 */ /* MCU Configuration----------------------------------------------------------*/ /* Reset of all peripherals, Initializes the Flash interface and the Systick. */ HAL_Init(); SystemClock_Config(); /* Initialize all configured peripherals */ MX_GPIO_Init(); MX_CAN_Init(); /* USER CODE BEGIN 2 */ CANTxMessage.DLC = 8; CANTxMessage.IDE = CAN_ID_STD; CANTxMessage.StdId = 0x07; CANTxMessage.RTR = CAN_RTR_DATA; CANTxMessage.Data[0] = 0; CANTxMessage.Data[1] = 10; CANTxMessage.Data[2] = 20; CANTxMessage.Data[3] = 30; CANTxMessage.Data[4] = 40; CANTxMessage.Data[5] = 50; CANTxMessage.Data[6] = 60; CANTxMessage.Data[7] = 70; /* USER CODE END 2 */ hcan.pTxMsg = &CANTxMessage; while (1) { /* USER CODE END WHILE */ HAL_Delay(100); HAL_CAN_Transmit(&hcan,100); /* USER CODE BEGIN 3 */ } } /** System Clock Configuration */ void SystemClock_Config(void) { RCC_OscInitTypeDef RCC_OscInitStruct; RCC_ClkInitTypeDef RCC_ClkInitStruct; /**Initializes the CPU, AHB and APB busses clocks */ RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE; RCC_OscInitStruct.HSEState = RCC_HSE_ON; RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON; RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE; RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL6; RCC_OscInitStruct.PLL.PREDIV = RCC_PREDIV_DIV1; if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } /**Initializes the CPU, AHB and APB busses clocks */ RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK |RCC_CLOCKTYPE_PCLK1; RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK; RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1; RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV1; if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_1) != HAL_OK) { _Error_Handler(__FILE__, __LINE__); } /**Configure the Systick interrupt time */ HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000); /**Configure the Systick */ HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK); /* SysTick_IRQn interrupt configuration */ HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0); } |
小白也能明白的STM32的低功耗与唤醒机制
STM32系统中2种数据掉电保护的方法
分享STM32F051中文参考手册(重制书签版)
AI工具训练营-用ChatGPT解决HID Keyboard实现的问题
STM32固件库分享,超全系列整理
STM32小白入门指南:从基础到OTA实现方案
STM32超详细学习笔记
新手必看!STM32单片机应该怎么学?
如果你解决了这些问题,就可以直接学STM32
