麻烦帮忙看一下关于MCU的SPI1配置是否有问题, GPIO_InitTypeDef GPIO_InitStruct; HAL_RCC_SPI1_CLK_ENABLE(); HAL_RCC_GPIOA_CLK_ENABLE(); // 2. 配置SPI1引脚 SCK - PA5 MISO - PA6 MOSI - PA7 HAL_GPIO_DeInit(GPIOA, GPIO_PIN_5|GPIO_PIN_6|GPIO_PIN_7);
GPIO_InitStruct.Pin = GPIO_PIN_5|GPIO_PIN_7;
GPIO_InitStruct.Mode = GPIO_MODE_AF_PP;
GPIO_InitStruct.Pull = GPIO_NOPULL;
GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_HIGH; // 初始化CS为高电平(未选中状态) GPIO_InitStruct.Pin = SPI1_CS_Pin;
GPIO_InitStruct.Mode = GPIO_MODE_OUTPUT_PP;
HAL_GPIO_Init(SPI1_CS_GPIO_Port, &GPIO_InitStruct);
HAL_GPIO_WritePin(SPI1_CS_GPIO_Port, SPI1_CS_Pin, GPIO_PIN_SET);
hspi1.Instance = SPI1;
hspi1.Init.Mode = SPI_MODE_MASTER;
hspi1.Init.Direction = SPI_DIRECTION_2LINES;
hspi1.Init.DataSize = SPI_DATASIZE_8BIT;
hspi1.Init.CLKPolarity = SPI_POLARITY_LOW;
hspi1.Init.CLKPhase = SPI_PHASE_2EDGE;
hspi1.Init.NSS = SPI_NSS_SOFT;
hspi1.Init.BaudRatePrescaler = SPI_BAUDRATEPRESCALER_16;
hspi1.Init.FirstBit = SPI_FIRSTBIT_MSB;
hspi1.Init.TIMode = SPI_TIMODE_DISABLE;
hspi1.Init.CRCCalculation = SPI_CRCCALCULATION_DISABLE;
hspi1.Init.CRCPolynomial = 7;
if (HAL_SPI_Init(&hspi1) != HAL_OK)
spiInit(&hspi1); 外部中断PA0配置 GPIO_InitTypeDef GPIO_Init_Struct; EXTI_ConfigTypeDef EXTI_Init_Struct; // 使能GPIOA和AFIO时钟 HAL_RCC_GPIOA_CLK_ENABLE(); HAL_RCC_AFIO_CLK_ENABLE(); // 配置PA0为外部中断输入 GPIO_Init_Struct.Pin = IRQ_3911_Pin; GPIO_Init_Struct.Mode = GPIO_MODE_IT_RISING; GPIO_Init_Struct.Pull = GPIO_NOPULL; GPIO_Init_Struct.Speed = GPIO_SPEED_FREQ_HIGH; HAL_GPIO_Init(IRQ_3911_GPIO_Port, &GPIO_Init_Struct); // 配置EXTI线0 EXTI_Init_Struct.Line = EXTI_LINE_0;
EXTI_Init_Struct.Mode = EXTI_MODE_INTERRUPT;
EXTI_Init_Struct.Trigger = EXTI_TRIGGER_RISING;
EXTI_Init_Struct.GPIOSel = EXTI_GPIOA; // 配置NVIC中断优先级 HAL_NVIC_SetPriority(EXTI0_IRQn, 0, 0); 目前是spi能够发送也能接收到信息,但不知道接收到的是否正确,但在初始化demoIni()后,轮询demoCycle();一直找不到UID |
FLASH擦除轮询等待时CPU真的会轮询吗
HAL_I2C_Mem_Read 一直返回 BUSY
KEILMDK每次都要手动选Reset and Run吗 不然下载到板子上得重启电源才行 求解答
STM32F103的USB的虚拟串口,串口助手打开的时候会收到两条数据,第一条数据是前5秒串口助手未打开时发送的,这怎么解决?
询问电源纹波对芯片的影响
VL53L5CX无法使用
stm32f107裸机+HR911105A+lwIP 1.31 SYN发送失败的问题
MCU的ADC进行电压采集时,外部输入阻抗最大能到多少?
