请教大家一个问题, 硬件是一样的,采样电阻接地。 负载不工作: AD单次采样时,可以采样到0x 00; AD+DMA连续采样,采样到 0x 0F到0x 12 抬高了采样值, 负载开启时: AD单次采样时,可以采样到0x 67 左右波动; AD+DMA连续采样,采样到 0x89 左右波动; 抬高了采样值,是我那里没有设置好吗,我就在例程上修改一个脚,从PC1改到PA1. include "adc.h"define ADC1_DR_Address ((u32)0x40012400+0x4c)__IO uint16_t ADC_ConvertedValue; static void ADC1_GPIO_Config(void) { GPIO_InitTypeDef GPIO_InitStructure; / Enable DMA clock / RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE); / Enable ADC1 and GPIOC clock / RCC_APB2PeriphClockCmd(RCC_APB2Periph_ADC1 | RCC_APB2Periph_GPIOA, ENABLE); / Configure PC.01 as analog input / GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN; GPIO_Init(GPIOA, &GPIO_InitStructure); // } static void ADC1_Mode_Config(void) { DMA_InitTypeDef DMA_InitStructure; ADC_InitTypeDef ADC_InitStructure; / DMA channel1 configuration / DMA_DeInit(DMA1_Channel1); DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address; // DMA_InitStructure.DMA_MemoryBaseAddr = (u32)&ADC_ConvertedValue;// DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC; DMA_InitStructure.DMA_BufferSize = 1; DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;// DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Disable; // DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord; // DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord; DMA_InitStructure.DMA_Mode = DMA_Mode_Circular; // DMA_InitStructure.DMA_Priority = DMA_Priority_High; DMA_InitStructure.DMA_M2M = DMA_M2M_Disable; DMA_Init(DMA1_Channel1, &DMA_InitStructure); / Enable DMA channel1 / DMA_Cmd(DMA1_Channel1, ENABLE); / ADC1 configuration / ADC_InitStructure.ADC_Mode = ADC_Mode_Independent; // ADC_InitStructure.ADC_ScanConvMode = DISABLE ; // ADC_InitStructure.ADC_ContinuousConvMode = ENABLE; // ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_None; // ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right; // ADC_InitStructure.ADC_NbrOfChannel = 1; // ADC_Init(ADC1, &ADC_InitStructure); RCC_ADCCLKConfig(RCC_PCLK2_Div8); ADC_RegularChannelConfig(ADC1, ADC_Channel_1, 1, ADC_SampleTime_55Cycles5); / Enable ADC1 DMA / ADC_DMACmd(ADC1, ENABLE); / Enable ADC1 / ADC_Cmd(ADC1, ENABLE); ADC_ResetCalibration(ADC1); while(ADC_GetResetCalibrationStatus(ADC1)); ADC_StartCalibration(ADC1); while(ADC_GetCalibrationStatus(ADC1)); ADC_SoftwareStartConvCmd(ADC1, ENABLE); } void ADC1_Init(void) { ADC1_GPIO_Config(); ADC1_Mode_Config(); } |
FLASH擦除轮询等待时CPU真的会轮询吗
HAL_I2C_Mem_Read 一直返回 BUSY
串口DMA收发出现ORE错误
有使用STM32芯片制作嵌入式PLC比较成熟的方案吗?
STM32F3系列SDADC外部触发 DMA运输的bug
KEILMDK每次都要手动选Reset and Run吗 不然下载到板子上得重启电源才行 求解答
STM32F103的USB的虚拟串口,串口助手打开的时候会收到两条数据,第一条数据是前5秒串口助手未打开时发送的,这怎么解决?
询问电源纹波对芯片的影响
你说的负载开启 与 不开启 具体啥意思?
另外你说的那个接地电阻又是多大?
楼主,您好。采集结果可以同步使用示波器进行对比。除非使用稳定电源,电阻这种由于温度等外界和电路的影响较大。产生波动是正常的,只要再范围内即可。12位的AD这点波动是正常的。
