STM32F103RCT6呼吸灯实验PWM调不出来,用的原子MINI 开发板,利用PA8 复用功能TIM1_CH1 输出PWM #include"stm32f10x.h" #include"sys.h" #define LED0 PAout(8) #define LED1 PDout(2) void SysTick_Init(u8 SYSCLK); //SysTick初始化函数声明 void delay_ms(u16 nms); //自定义的延时毫秒函数声明 void GPIO_Configuration(void); //GPIO端口初始化设置函数声明 void TIM1_PWM_Init(u16 arr,u16 psc);//定时器1初始化设置配置成PWM输出函数声明 u8 fac_us=0; u16 fac_ms=0; int main(void) { u16 led0pwmval=0; u8 dir=1; SysTick_Init(72); // 调用SysTick初始化函数 //NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2); GPIO_Configuration(); TIM1_PWM_Init(899,0);//不分频。PWM频率=72000/(899+1)=80Khz while(1) { delay_ms(10); if(dir)led0pwmval++; else led0pwmval--; if(led0pwmval>300)dir=0; if(led0pwmval==0)dir=1; TIM_SetCompare1(TIM1,led0pwmval); } } void SysTick_Init(u8 SYSCLK) //SysTick初始化函数 {SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK_Div8); fac_us=SYSCLK/8; //SYSCLK的8分频 保存1us所需的计数次数 fac_ms=(u16)fac_us*1000; //1ms 需要计数的次数 } void GPIO_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOD, ENABLE);//使能PA,PD外设端口时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE); GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; //LED0-->PA8 端口配置 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度为50MHz GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出,TIM1_CH1输出PWM脉冲波形 GPIO_Init(GPIOA, &GPIO_InitStructure); //根据设定参数初始化GPIOA.8 // GPIO_SetBits(GPIOA,GPIO_Pin_8); //PA8 输出高 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2; //LED1-->PD2 端口配置 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; //IO口速度为50MHz GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; GPIO_Init(GPIOD, &GPIO_InitStructure); //根据设定参数初始化GPIOD.2,推挽输出,IO口速度为50MHz GPIO_SetBits(GPIOD,GPIO_Pin_2); //PD.2 输出高 } void TIM1_PWM_Init(u16 arr,u16 psc) { TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure; TIM_OCInitTypeDef TIM_OCInitStructure; TIM_TimeBaseStructure.TIM_Period = arr; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值 80K TIM_TimeBaseStructure.TIM_Prescaler =psc; //设置用来作为TIMx时钟频率除数的预分频值 不分频 TIM_TimeBaseStructure.TIM_ClockDivision = 0; //设置时钟分割:TDTS = Tck_tim TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式 TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位 TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //选择定时器模式:TIM脉冲宽度调制模式2 TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比较输出使能 TIM_OCInitStructure.TIM_Pulse = 0; //设置待装入捕获比较寄存器的脉冲值 TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //输出极性:TIM输出比较极性高 TIM_OC1Init(TIM1, &TIM_OCInitStructure); //根据TIM_OCInitStruct中指定的参数初始化外设TIMx TIM_CtrlPWMOutputs(TIM1,ENABLE); //MOE 主输出使能 TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Enable); //CH1预装载使能 TIM_ARRPreloadConfig(TIM1, ENABLE); //使能TIMx在ARR上的预装载寄存器 TIM_Cmd(TIM1, ENABLE); //使能TIM1 } void delay_ms(u16 nms) //利用SysTick自定义的延时毫秒函数 最长延时1864ms {u32 temp; SysTick->LOAD=(u32)nms*fac_ms; // nms毫秒需要装载的寄存器值 SysTick->VAL =0x00; //清空计数器 SysTick->CTRL=0x01; //开始倒数 do{temp=SysTick->CTRL;} while ((temp&0x01)&&!(temp&(1<<16))); //等待时间到达 SysTick->CTRL&=~0x01; //关闭计数器 SysTick->VAL =0X00; //清空计数器 } |
FLASH擦除轮询等待时CPU真的会轮询吗
HAL_I2C_Mem_Read 一直返回 BUSY
KEILMDK每次都要手动选Reset and Run吗 不然下载到板子上得重启电源才行 求解答
STM32F103的USB的虚拟串口,串口助手打开的时候会收到两条数据,第一条数据是前5秒串口助手未打开时发送的,这怎么解决?
询问电源纹波对芯片的影响
VL53L5CX无法使用
stm32f107裸机+HR911105A+lwIP 1.31 SYN发送失败的问题
MCU的ADC进行电压采集时,外部输入阻抗最大能到多少?
//RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE);
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //复用推挽输出,TIM1_CH1输出PWM脉冲波形
RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1, ENABLE); //使能TIM1外设时钟
{u32 temp;
先不用主循环,只给 TIM_Pulse 设定几个不同的固定值,看亮度有变化没。
比如,0,50,200,400,800
如果把void GPIO_Configuration(void)函数里的
这些都打//屏蔽掉
移动加到void TIM1_PWM_Init(u16 arr,u16 psc)函数里边,PWM呼吸灯就正常了, 有点奇怪,想不通
