实验平台:Nucleo-STM32G474RE开发板 验证功能:希望利用DMA把数据传到DAC3的DAC_DHR12R1寄存器产生波形,再通过运放的跟随输出到外部管脚 问题描述:DMA没有更新DAC3的DHR12R1寄存器数据,进而无波形产生 DAC3配置: static void MX_DAC3_Init(void) { /* USER CODE BEGIN DAC3_Init 0 */ /* USER CODE END DAC3_Init 0 */ DAC_ChannelConfTypeDef sConfig = {0}; /* USER CODE BEGIN DAC3_Init 1 */ /* USER CODE END DAC3_Init 1 */ /** DAC Initialization */ hdac3.Instance = DAC3; if (HAL_DAC_Init(&hdac3) != HAL_OK) { Error_Handler(); } /** DAC channel OUT1 config */ sConfig.DAC_HighFrequency = DAC_HIGH_FREQUENCY_INTERFACE_MODE_AUTOMATIC; sConfig.DAC_DMADoubleDataMode = DISABLE; sConfig.DAC_SignedFormat = DISABLE; sConfig.DAC_SampleAndHold = DAC_SAMPLEANDHOLD_DISABLE; sConfig.DAC_Trigger = DAC_TRIGGER_T2_TRGO; sConfig.DAC_Trigger2 = DAC_TRIGGER_NONE; sConfig.DAC_OutputBuffer = DAC_OUTPUTBUFFER_DISABLE; sConfig.DAC_ConnectOnChipPeripheral = DAC_CHIPCONNECT_ENABLE; sConfig.DAC_UserTrimming = DAC_TRIMMING_FACTORY; if (HAL_DAC_ConfigChannel(&hdac3, &sConfig, DAC_CHANNEL_1) != HAL_OK) { Error_Handler(); } /* USER CODE BEGIN DAC3_Init 2 */ /* USER CODE END DAC3_Init 2 */ } OPAMP1配置 static void MX_OPAMP1_Init(void) { /* USER CODE BEGIN OPAMP1_Init 0 */ /* USER CODE END OPAMP1_Init 0 */ /* USER CODE BEGIN OPAMP1_Init 1 */ /* USER CODE END OPAMP1_Init 1 */ hopamp1.Instance = OPAMP1; hopamp1.Init.PowerMode = OPAMP_POWERMODE_NORMAL; hopamp1.Init.Mode = OPAMP_FOLLOWER_MODE; hopamp1.Init.NonInvertingInput = OPAMP_NONINVERTINGINPUT_DAC; hopamp1.Init.InternalOutput = DISABLE; hopamp1.Init.TimerControlledMuxmode = OPAMP_TIMERCONTROLLEDMUXMODE_DISABLE; hopamp1.Init.UserTrimming = OPAMP_TRIMMING_FACTORY; if (HAL_OPAMP_Init(&hopamp1) != HAL_OK) { Error_Handler(); } /* USER CODE BEGIN OPAMP1_Init 2 */ /* USER CODE END OPAMP1_Init 2 */ } TIMER2配置: static void MX_TIM2_Init(void) { /* USER CODE BEGIN TIM2_Init 0 */ /* USER CODE END TIM2_Init 0 */ TIM_ClockConfigTypeDef sClockSourceConfig = {0}; TIM_MasterConfigTypeDef sMasterConfig = {0}; /* USER CODE BEGIN TIM2_Init 1 */ /* USER CODE END TIM2_Init 1 */ htim2.Instance = TIM2; htim2.Init.Prescaler = 0; htim2.Init.CounterMode = TIM_COUNTERMODE_UP; htim2.Init.Period = 169; htim2.Init.ClockDivision = TIM_CLOCKDIVISION_DIV1; htim2.Init.AutoReloadPreload = TIM_AUTORELOAD_PRELOAD_DISABLE; if (HAL_TIM_Base_Init(&htim2) != HAL_OK) { Error_Handler(); } sClockSourceConfig.ClockSource = TIM_CLOCKSOURCE_INTERNAL; if (HAL_TIM_ConfigClockSource(&htim2, &sClockSourceConfig) != HAL_OK) { Error_Handler(); } sMasterConfig.MasterOutputTrigger = TIM_TRGO_UPDATE; sMasterConfig.MasterSlaveMode = TIM_MASTERSLAVEMODE_DISABLE; if (HAL_TIMEx_MasterConfigSynchronization(&htim2, &sMasterConfig) != HAL_OK) { Error_Handler(); } /* USER CODE BEGIN TIM2_Init 2 */ /* USER CODE END TIM2_Init 2 */ } DMA配置: static void MX_DMA_Init(void) { /* DMA controller clock enable */ __HAL_RCC_DMAMUX1_CLK_ENABLE(); __HAL_RCC_DMA1_CLK_ENABLE(); /* DMA interrupt init */ /* DMA1_Channel1_IRQn interrupt configuration */ HAL_NVIC_SetPriority(DMA1_Channel1_IRQn, 0, 0); HAL_NVIC_EnableIRQ(DMA1_Channel1_IRQn); } 主程序: /* Initialize all configured peripherals */ MX_GPIO_Init(); MX_DMA_Init(); MX_DAC3_Init(); MX_OPAMP1_Init(); MX_TIM2_Init(); /* USER CODE BEGIN 2 */ for (i=0;i<NUM;i++) { sinetable[i]=(uint16_t)((pow(2,12)-1)*(sin((double)i/NUM*2*Pi))); } HAL_OPAMP_Start(&hopamp1); HAL_TIM_Base_Start(&htim2); HAL_DAC_Start_DMA(&hdac3,DAC_CHANNEL_1,(uint32_t *)sinetable,NUM,DAC_ALIGN_12B_R); 问题:无波形产生,但是用软件设定值的话,可以观察到输出电压有反应,可以定位于DAC的DMA模式不工作,进而调试发现初始化的时候DMA1的EN可以使能,接着程序跑起来后EN一直就为0,如果强制把EN置1,则过后软件马上把EN清0,同时DMA的ISR寄存器中的TEIF1和GIF1被置1,说明有传输错误。请问是DMA哪里配置有问题,忽视了什么吗?谢谢 |
FLASH擦除轮询等待时CPU真的会轮询吗
NUCLEO G474RE无法运行程序
电子方案大会深圳站-ST展台
NUCLEO-G474RE这个开发板的例程在哪儿下载啊,不知道如和用他的usb和pc串口通信
STM32G431 用MCSDK5.4.8 进行PMSM永磁同步电机FOC控制,转速上升到某一值(3500rpm)无法继续上升,上不去
stm32g474cct6 flash地址问题
HRTIM中已经设置了两路独立输出,第二路无法设置触发源,提示必须是0
记录使用Cube生成HRTIM工程时的一个bug
stm32 usb hid设备能发数据给PC,但不能接收PC的数据!!!
STSPIN32G4 STM32G431VBTx CAN FIFO发送数据帧随机变远程帧
这句改成 DAC_OUTPUTBUFFER_ENABLE 试试
谢谢您的回复,可能您不熟悉STM32G4的芯片,DAC3输出不能达到管脚,只有内部连接,如果要输出来,只能从内部接到运放的非反相端,按照跟随器的方式输出,所以这里只能这样的配置
