#ifdef SPI3_NSS_HARD #define SPI3_CS_ENABLE SPI_Cmd(SPI3, ENABLE) #define SPI3_CS_DISABLE SPI_Cmd(SPI3, DISABLE) #else #define SPI3_CS_ENABLE PAout(15)=0 #define SPI3_CS_DISABLE PAout(15)=1 #endif void SPI3_Configuration(void) { SPI_InitTypeDef SPI_InitStructure; GPIO_InitTypeDef GPIO_InitStructure; RCC_APB1PeriphClockCmd(RCC_APB1Periph_SPI3, ENABLE); RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO, ENABLE); GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable, ENABLE);//JTAG Disable SWDP Enable GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOB, &GPIO_InitStructure); /* SPI: CS推挽输出 */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; #ifdef SPI3_NSS_HARD GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; #else GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; #endif GPIO_Init(GPIOA, &GPIO_InitStructure); /* SPI 初始化定义 */ SPI_InitStructure.SPI_Direction = SPI_Direction_2Lines_FullDuplex; //SPI设置为双线双向全双工 SPI_InitStructure.SPI_Mode = SPI_Mode_Master; //设置为主 SPI SPI_InitStructure.SPI_DataSize = SPI_DataSize_8b; //SPI发送接收 8 位帧结构 SPI_InitStructure.SPI_CPOL = SPI_CPOL_High; //时钟悬空高 SPI_InitStructure.SPI_CPHA = SPI_CPHA_2Edge; //数据捕获于第二个时钟沿 #ifdef SPI3_NSS_HARD SPI_InitStructure.SPI_NSS = SPI_NSS_Hard; //硬件控制 NSS 信号 #else SPI_InitStructure.SPI_NSS = SPI_NSS_Soft; //软件控制 NSS 信号 #endif SPI_InitStructure.SPI_BaudRatePrescaler = SPI_BaudRatePrescaler_2; //波特率预分频值为2 SPI_InitStructure.SPI_FirstBit = SPI_FirstBit_MSB; //数据传输从 MSB 位开始 SPI_InitStructure.SPI_CRCPolynomial = 7; //定义了用于 CRC值计算的多项式 SPI_Init(SPI3, &SPI_InitStructure); #ifdef SPI3_NSS_HARD SPI_SSOutputCmd(SPI3, ENABLE); SPI_Cmd(SPI3, DISABLE); #else SPI_Cmd(SPI3, ENABLE); #endif DMA_Config(); } 如上定义宏SPI3_NSS_HARD配置为硬件控制NSS输出,现烧录两个硬件:一个是采用HSI+PLL时钟64MHz,另一个采用HSE+PLL时钟72MHz。 测试如下代码: void SFLASH_FastReadNByte(uint8_t* pBuffer, uint32_t ReadAddr, uint16_t nByte) { while (PAin(15)==0);//Wait CS Disable SFLASH_WaitForNoBusy(); SPI3_CS_ENABLE; //使能器件 SPI3_WriteByte(SFLASH_FAST_READ); //《快读数据》指令 SPI3_WriteByte((uint8_t)((ReadAddr)>>16)); //发送24bit地址 SPI3_WriteByte((uint8_t)((ReadAddr)>>8)); SPI3_WriteByte((uint8_t)ReadAddr); SPI3_WriteByte(0xFF); //等待8个时钟 while(nByte--) //循环读数 { *pBuffer = SPI3_ReadByte(); pBuffer++; } SPI3_CS_DISABLE; //失能器件 } uint8_t SPI3_WriteByte(uint8_t TxData) { while((SPI3->SR & SPI_I2S_FLAG_TXE) == (uint16_t)RESET); SPI3->DR = TxData; while((SPI3->SR & SPI_I2S_FLAG_RXNE) == (uint16_t)RESET);//发现程序会卡在此处 return SPI3->DR; } 发现64MHz硬件运行正常,但72MHz时钟硬件程序会卡在“while((SPI3->SR & SPI_I2S_FLAG_RXNE) == (uint16_t)RESET);”导致异常复位,而如果不采用硬件控制NSS信号输出(即不定义宏SPI3_NSS_HARD)则都不会有此问题。到底是我的代码有bug还是在运行SPI_Cmd(SPI3, ENABLE)使能SPI后到SPI正常工作有延迟。请高人指教。 |
FLASH擦除轮询等待时CPU真的会轮询吗
HAL_I2C_Mem_Read 一直返回 BUSY
KEILMDK每次都要手动选Reset and Run吗 不然下载到板子上得重启电源才行 求解答
STM32F103的USB的虚拟串口,串口助手打开的时候会收到两条数据,第一条数据是前5秒串口助手未打开时发送的,这怎么解决?
询问电源纹波对芯片的影响
VL53L5CX无法使用
stm32f107裸机+HR911105A+lwIP 1.31 SYN发送失败的问题
MCU的ADC进行电压采集时,外部输入阻抗最大能到多少?
