调试STM32F103 与 STM32F407两个板子互相通信都通过了,500k波特率都没什么问题,可以在STM32F107Vc上面就是不能正确设置波特率。 波特率配置代码如下: //CAN1_Mode_Init(CAN_SJW_1tq, CAN_BS2_8tq, CAN_BS1_7tq, 1, mode); // CAN普通模式初始化,普通模式,波特率500Kbps //CAN1_Mode_Init(CAN_SJW_1tq, CAN_BS2_8tq, CAN_BS1_3tq, 6, mode); // CAN普通模式初始化,普通模式,波特率500Kbps //CAN1_Mode_Init(CAN_SJW_1tq, CAN_BS2_8tq, CAN_BS1_9tq, 8, mode); // 普通模式初始化,普通模式,波特率500Kbps //CAN1_Mode_Init(CAN_SJW_1tq, CAN_BS2_3tq, CAN_BS1_2tq, 12, mode);//500k CAN1_Mode_Init(CAN_SJW_1tq, CAN_BS2_1tq, CAN_BS1_4tq, 24, mode); //36m 1000k 几个都试了,就是不行示波器测量有波形,但与407,103发同样数据,数据周期都不一样。 初始化函数: u8 CAN1_Mode_Init(u8 tsjw,u8 tbs2,u8 tbs1,u16 brp,u8 mode) { GPIO_InitTypeDef GPIO_InitStructure; CAN_InitTypeDef CAN_InitStructure; CAN_FilterInitTypeDef CAN_FilterInitStructure; #if CAN1_RX0_INT_ENABLE NVIC_InitTypeDef NVIC_InitStructure; #endif //使能相关时钟 RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);//使能PORTA时钟 RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN1, ENABLE);//使能CAN1时钟 //初始化GPIO GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOB, &GPIO_InitStructure); //初始化PB8 /* Configure CAN pin: TX */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; GPIO_Init(GPIOB, &GPIO_InitStructure); GPIO_PinRemapConfig(GPIO_Remap1_CAN1, ENABLE );//重影射CAN IO脚到 PB8,PB9 //CAN单元设置 CAN_InitStructure.CAN_TTCM=DISABLE; //非时间触发通信模式 CAN_InitStructure.CAN_ABOM=DISABLE; //软件自动离线管理 CAN_InitStructure.CAN_AWUM=DISABLE; / CAN_InitStructure.CAN_NART=ENABLE; //禁止报文自动传送 CAN_InitStructure.CAN_RFLM=DISABLE; //报文不锁定,新的覆盖旧的 CAN_InitStructure.CAN_TXFP=DISABLE; //优先级由报文标识符决定 CAN_InitStructure.CAN_Mode= mode; //模式设置 CAN_InitStructure.CAN_SJW=tsjw; //重新同步跳跃宽度(Tsjw)为tsjw+1个时间单位 CAN_SJW_1tq~CAN_SJW_4tq CAN_InitStructure.CAN_BS1=tbs1; //Tbs1范围CAN_BS1_1tq ~CAN_BS1_16tq CAN_InitStructure.CAN_BS2=tbs2; //Tbs2范围CAN_BS2_1tq ~ CAN_BS2_8tq CAN_InitStructure.CAN_Prescaler=brp; //分频系数(Fdiv)为brp+1 CAN_Init(CAN1, &CAN_InitStructure); // 初始化CAN1 //配置过滤器 CAN_FilterInitStructure.CAN_FilterNumber=0; //过滤器0 CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask; CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit; //32位 CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000; ////32位ID CAN_FilterInitStructure.CAN_FilterIdLow=0x0000; CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000; //32位MASK CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000; CAN_FilterInitStructure.CAN_FilterFIFOAssignment = 0; //过滤器0关联到FIFO0 CAN_FilterInitStructure.CAN_FilterActivation=ENABLE; //激活过滤器0 CAN_FilterInit(&CAN_FilterInitStructure); //滤波器初始化 #if CAN1_RX0_INT_ENABLE CAN_ITConfig(CAN1,CAN_IT_FMP0,ENABLE);//FIFO0消息挂号中断允许. NVIC_InitStructure.NVIC_IRQChannel = CAN1_RX0_IRQn; NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1; // 主优先级为1 NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0; // 次优先级为0 NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; NVIC_Init(&NVIC_InitStructure); #endif return 0; } |
【福利三:雨露均沾·逢7狂欢】之三:AI帮我查BUG
基于STM32F103的I2C主从机通信
单片机:初学者该了解的STM32F103基础知识
2025软件工具兔哥知道
STM32之继电器模块
STM32F103时APB CLK = 36M
对于STM32F107是多少
另一个107的板子电压差是1.0V,怎么会事?
keil自带的例程中系统时钟配置文件应该OK了,
注明STM32F103时APB CLK = 42M,怎么配置的没看明白,待有时间的了仔细再看看。
APB CLK = 42M
CAN1_Mode_Init(CAN_SJW_4tq, CAN_BS2_5tq, CAN_BS1_12tq, 4, mode);
