下面是我的配置代码: static void GPIO_USART1_Configuration(void) { GPIO_InitTypeDef GPIO_InitStructure; RCC_AHBPeriphClockCmd(RCC_AHBPeriph_GPIOA, ENABLE); GPIO_PinAFConfig(GPIOUSART1, GPIO_PinSource9, GPIO_AF_1); GPIO_PinAFConfig(GPIOUSART1, GPIO_PinSource10, GPIO_AF_1); /* GPIO_PIN9 -> USART1-TX GPIO_PIN10 -> USART1-RX */ GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9 | GPIO_Pin_10 ; GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; GPIO_Init(GPIOUSART1, &GPIO_InitStructure); } void USART1_Configuration(void) { USART_InitTypeDef USART_InitStructure; GPIO_USART1_Configuration(); RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1, ENABLE); USART_InitStructure.USART_BaudRate = 9600; USART_InitStructure.USART_WordLength = USART_WordLength_8b; USART_InitStructure.USART_StopBits = USART_StopBits_1; USART_InitStructure.USART_Parity = USART_Parity_No; USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; USART_Init(USART1, &USART_InitStructure); USART_Cmd(USART1, ENABLE);//ʹÄÜ´®¿Ú1 } void UART1_send_byte(uint8_t byte) { while(!((USART1->ISR)&(1ISR)&(1ISR & (1CR |= (uint32_t)0x00000001; /* Reset SW[1:0], HPRE[3:0], PPRE[2:0], ADCPRE and MCOSEL[2:0] bits */ RCC->CFGR &= (uint32_t)0xF8FFB80C; /* Reset HSEON, CSSON and PLLON bits */ RCC->CR &= (uint32_t)0xFEF6FFFF; /* Reset HSEBYP bit */ RCC->CR &= (uint32_t)0xFFFBFFFF; /* Reset PLLSRC, PLLXTPRE and PLLMUL[3:0] bits */ RCC->CFGR &= (uint32_t)0xFFC0FFFF; /* Reset PREDIV1[3:0] bits */ RCC->CFGR2 &= (uint32_t)0xFFFFFFF0; /* Reset USARTSW[1:0], I2CSW, CECSW and ADCSW bits */ RCC->CFGR3 &= (uint32_t)0xFFFFFEAC; /* Reset HSI14 bit */ RCC->CR2 &= (uint32_t)0xFFFFFFFE; /* Disable all interrupts */ RCC->CIR = 0x00000000; /* Configure the System clock frequency, AHB/APBx prescalers and Flash settings */ SetSysClock(); } static void SetSysClock(void) { __IO uint32_t StartUpCounter = 0, HSEStatus = 0; /* SYSCLK, HCLK, PCLK configuration ----------------------------------------*/ /* Enable HSE */ RCC->CR |= ((uint32_t)RCC_CR_HSEON); /* Wait till HSE is ready and if Time out is reached exit */ do { HSEStatus = RCC->CR & RCC_CR_HSERDY; StartUpCounter++; } while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT)); if ((RCC->CR & RCC_CR_HSERDY) != RESET) { HSEStatus = (uint32_t)0x01; } else { HSEStatus = (uint32_t)0x00; } if (HSEStatus == (uint32_t)0x01) { /* Enable Prefetch Buffer */ FLASH->ACR |= FLASH_ACR_PRFTBE; FLASH->ACR |= (uint32_t)FLASH_ACR_LATENCY; /* HCLK = SYSCLK */ RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1; /* PCLK = HCLK */ RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV1; /* PLL configuration: = HSE * 4 = 40 MHz */ RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL)); RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL4); /* Enable PLL */ RCC->CR |= RCC_CR_PLLON; /* Wait till PLL is ready */ while((RCC->CR & RCC_CR_PLLRDY) == 0) { } /* Select PLL as system clock source */ RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW)); RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL; /* Wait till PLL is used as system clock source */ while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)0x08) { } } else { /* If HSE fails to start-up, the application will have wrong clock configuration. User can add here some code to deal with this error */ } } 调了两天了,一直找不到问题, ![]() |
STM32 是否有各种接口的官方 Bootloader 方案
STM32的硬件部分
无源晶振开关电路设计
调试时出现 HardFault_Handler 问题该如何解决?
stm32 数据掉电保存问题
手动按键复位可以保存变量, 但是断电马上上电却不能了. 有什么办法可以解决吗?
RST问题请教
HAL_I2C_Mem_Read_IT读取INA226多个寄存器只有第一个寄存器是对的,其他全为0XFF
stm32电源部分
ST MotorControl Workbench 生成代码过程中报错Java的非法反射警告
回复:求教 STM32F05 串口通信收发不一致
