F103求助USART3无法工作,MDK仿真能够输出,但板子不能打印
luokanx
提问时间:2016-12-28 17:13 /
发布时间:2016-12-28 17:13
18个回答
damiaa
回答时间:2016-12-29 15:14:21
a1024a.1 32b0c
zbber
回答时间:2016-12-29 16:13:55
a0a.1 32b0c
重新整理了一下
andypanfan
回答时间:2016-12-30 09:05:26
a0a.1 32b0c
#ifndef __USART3_H
#define __USART3_H
#include "sys.h"
#include "delay.h"
#include "string.h"
#include <stdlib.h>
#include "time3.h"
#define TX3_buf_size 30
#define RX3_buf_size 30
extern u8 USART3_RX_CNT;
extern u8 USART3_RX_BUF[RX3_buf_size];
extern u8 USART3_TX_BUF[TX3_buf_size];
void usart3_init(u32 bound);
void usart3_Send_Data(u8 *buf,u8 len);
void clear_usart3_receive_buf(void);
#endif
#include "usart3.h"
//#if 1
//#pragma import(__use_no_semihosting)
//struct __FILE
// int handle;
//FILE __stdout;
//_sys_exit(int x)
// x = x;
//int fputc(int ch, FILE *f)
// while((USART3->SR&0X40)==0);
// USART3->DR = (u8) ch;
// return ch;
//#endif
u8 usart3_receive_data_flag=0;
u8 USART3_RX_CNT=0;
u8 USART3_RX_BUF[RX3_buf_size]={0};
u8 USART3_TX_BUF[TX3_buf_size]={0};
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_AFIO, ENABLE);
USART_DeInit(USART3);
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10; //USART3_TX PB10
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11; //USART3_RX PB11
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING; //浮空输入
NVIC_InitStructure.NVIC_IRQChannel = USART3_IRQn; //Usart3 NVIC 配置
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=3 ; //抢占优先级3
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2; //子优先级3
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道使能
USART_InitStructure.USART_BaudRate = bound; //一般设置为9600;
USART_InitStructure.USART_WordLength = USART_WordLength_8b; //字长为8位数据格式
USART_InitStructure.USART_StopBits = USART_StopBits_1; //一个停止位
USART_InitStructure.USART_Parity = USART_Parity_No; //无奇偶校验位
USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None; //无硬件数据流控制
USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx; //收发模式
USART_Init(USART3, &USART_InitStructure); //初始化串口
USART_ITConfig(USART3, USART_IT_RXNE, ENABLE); //开启中断
USART_Cmd(USART3, ENABLE);
void USART3_IRQHandler(void) //串口1中断服务程序
unsigned char usart3_rece_dat=0;
if(USART_GetITStatus(USART3, USART_IT_RXNE)==SET) //接收中断
usart3_rece_dat=USART_ReceiveData(USART3);
if(USART3_RX_CNT<sizeof(USART3_RX_BUF)) //最多接收30个字节的数据
USART3_RX_BUF[USART3_RX_CNT]=usart3_rece_dat; //记录接收到的值
USART3_RX_CNT++; //接收数据增加1
} //USART_ReceiveData(USART1);
u8 t;
for(t=0;t<len;t++) //循环发送数据
while(USART_GetFlagStatus(USART3, USART_FLAG_TC) == RESET);
USART_SendData(USART3,buf[t]);
memset(USART3_RX_BUF,0,sizeof(USART3_RX_BUF));
USART3_RX_CNT=0;
这是我以前测试过的代码 你看看!!!
参与人数
1
ST金币
+2
收起
理由
zero99
+ 2
rowen800
回答时间:2016-12-30 16:57:50
a0a.1 32b0c
检测串口打印那块的配置
2
/ 2 页
